okay i wont do that, thank you Wbahn, here i tried to make my work more clearI don't think there's any need to start a new thread dealing with this same problem. It will just cause confusion as people end up posting to one, the other, or both threads. Let's keep it all in one place, okay?
Frequency = 1000 Hz
Z1 = 69j ohms: Inductor
Z2 = 37 ohms: Resistor
Z3 = -111j ohms: Capacitor
Z4 = 119 ohms: Resistor
Z5 = Load impedance
Vs = 78 + j270 V
Vx = 4+ j140 V
i started by using a delta-wye transformation and i got this (i attached a pic that i used to do the transformation) :
Za =(Z1*Z2)/(Z1+Z2+Z3)=-34.22+j30.15 ohms
Zb =(Z2*Z3)/(Z1+Z2+Z3)=55.05-j48.50 ohms
Zc =(Z1*Z3)/(Z1+Z2+Z3)=90.45+102.67 ohms
then i wen to take Z5 which is the load then to find the total current i did
it =(Vs-Vx)/(Za+Zc+Z4)
Vza= -it*za
Vzc= -it*zc
Vz4= it*z4
so Eth = Vs+Vza or Eth= -Vzc+Vz4+Vx so if you would like to check my work and see if what i did is correct I would really appreciate it. Thank you.
