Help with a motion detector.
Metalica
Joined Aug 1, 2010
42
Ok the module is this.
https://www.epal.pk/product/rcwl-0516-microwave-radar-human-inductive-motion-sensor/
Now i want to power it with 4 AA batteries that makes 1.5*4=6 Volt
here are some specs when it detects motion.
It outputs 3.2-3.4V when motion detected at one of its pins.
Output 100mA current is max output.
now what i want is to take that output and feed it to a very simple 1 transistor circuit that is powered by the same 6 volt batteries set that can give me 6 volts with more amps and Should be as simple as possible to achieve simplicity and less space.
Thats all.
Metalica
Joined Aug 1, 2010
42
I have a bunch of C828 NPN transistors.
I want it to create high decibel sound
What if i need to power a larger buzzer with more dB sound like 130db and 2 watt specification.
Metalica
Joined Aug 1, 2010
42
Ok dear what i am trying to create is a product that can be used as a burglar alarm with high decibel sound so please guide me for getting a good buzzer for this purpose and feed it through some circuit....
Metalica
Joined Aug 1, 2010
42
Ok Good now design me a circuit that can drive this i can upgrade the 6 volt supply to 12 volt and a good battery.
ericgibbs
Joined Jan 29, 2010
21,585
hi,
The uWave sensor can operate from 12V, so can the siren.
All you need is a MOSFET, rated at say Id=1Amp and Vgs of < 2V. say a SI2300.
A 1k resistor from uWave out to the MOSFET Gate.
Sketch out and post a circuit, we can check
Add power line decoupling, say a 47ouF and 100nF caps
E
Metalica
Joined Aug 1, 2010
42
Sir please help me i need a 6 volt design for this system with a 6 volt buzzer with 130 db sound and 200mA specs.
visionofast
Joined Oct 17, 2018
106
As an additional info, notice that these uw modules may even detect motions behind the walls,and are sensitive to any kind of motions unlike the PIR sensors that are mostly snesitive to movement of thermal-emiting objects (like human or animal's body).
Metalica
Joined Aug 1, 2010
42
I need to create a simple PIR alarm as above but instead of a buzzer i want to use this https://www.alibaba.com/product-det...m=a2700.7724857.normalList.175.62396044LehupM
The website has mentioned these specs for it.
DC12V/24V
Rated current 3A/2A
please some one guide me for a suitable but a one transistor solution to this problem. the operating voltage will be a 12v bike battery instead of a 9v as circuit shows above.
Or
If some one has a better option to use instead of the siren i posted in the link please share that.
Thank you.
Metalica
Joined Aug 1, 2010
42
But the problem is that i want to do it only using BJTs, please no MOSFETs since i can't find them or i am not comfortable with them.
