Hi, I need some help identifying this thing.
It is used as an igniter. A wire is soldered on each side. A discharge causes the plate to ignite with a white flame. The plate appears to be covered with copper, and then a silvery soft metal probably magnesium. The composite material inside is unknown, but it does have some obvious texture. It has a resistance of 1.2 ohm. Any ideas? Any and all help would be greatly appreciated!
