Help wanted, circuit for regular pulse variable phase shift.
cork_ie
Joined Oct 8, 2011
428
Hi Folks,I posted this some time ago when the ban on automotive questions was in force. Although I deemed it test gear and not a mod I never got to pursue the project.
I need some help. I have checked the archives and can only find time interval pulse delay circuits.
I have two wheels driven together at 2:1 ratio. Wheel 1 spins at twice the speed of wheel 2.
Wheel 1 is toothed and generates regular pulses with a missing tooth to indicate position. Sensor is either a magnetic coil or Hall effect type.
Wheel 2 turns at half the speed of wheel 1 - rate of rotation is approx 10 times/sec to 60 times/sec. It has a marker tooth which generates a pulse by switching a Hall effect sensor.
I need to advance & delay the pulse from wheel 2 by -10 Deg of angular rotation to + 10 Deg of angular rotation. The angular shift to remain steady irrespective of speed of rotation.
What I am actually trying to do is make a simulator for a stretched timing chain in an engine. By varying the phase angle of the camshaft pulse I would be able to determine whether it is the chain or the chain tensioner that is in trouble.
I know that an oscilloscope would allow me to see what is happening, but without a good waveform to start with it, it would be next to impossible to make a confirmed diagnosis. This way I can adjust the "apparent valve timing" ie what the ECU sees, electronically and increase or decrease the angular offset until such time as a diagnostic trouble code is set. That way I can exactly determine the true mid point.
I was hoping I would be able to achieve a - 10 deg delay by shifting the pulse from wheel 1 and the + by shifting the pulse on wheel 2 - effectively two circuits, only one operating at any given time.
I would prefer to avoid using a software based solution but if I have no option I will accept all suggestions.
Thanks in anticipation
Dodgydave
Joined Jun 22, 2012
11,395
How many pulses a second is the fast wheel 1, 20 to 120 per second? (20 to 120Hz)
So wheel 2 is half this at 10 to 60 pulses a second? (10 to 60Hz)
How long is the pulse width, and what voltage ?
danadak
Joined Mar 10, 2018
4,057
One could consider using DDS technology, maybe a PLL to phase lock
the DDS to the source then use its internal phase accumulator and phase
register to set / modulate phase. But some code involved to handle the registers,
the rest simple HW.
Regards, Dana.
cork_ie
Joined Oct 8, 2011
428
The crank(wheel 1) pulse rate is generally higher due to the number of "teeth" which varies from about 40 to 80 per 360 Deg of rotation
the rpm range I am interested in is 180-1200 RPM = 3 to 200 per second x no of teeth = 120 to 16,000 pulses per second.
Cam sensor Wheel two , which is far simpler and is invariably a Hall sensor is 1 to 4 teeth and turns at half crank speed i.e. 1.5 to 100 turns per second pulse range is 1.5 to 400 per second. I want to intercept this pulse and advance or delay it. +/- 10deg of crankshaft rotation 5Deg of cam rotation. Delaying the signal by 350 Deg if needed is OK
Because the crank signal is so variable I wish to avoid using it as a reference, if at all possible.
The ideal is to use the cam signal as the reference pass it through my "Black box" and insert a delay by a variable percentage ( potentiometer or otherwise) and then output the same signal to the ECU.
The time between pulses, as calculated above, varies from 2.5 milliseconds to 667 ms. The delay would be 0-2.7% of that (10Deg) of that . Pulse width is < 1deg = 0.27% 6.75 us to 1.8ms.
The important thing is that the delay is a phase shift and independent of frequency.
