Help transistor switch
kenny-one
Joined Apr 21, 2010
37
Hi guys
I designed the attached transistor switch, the problem with it is that the negative part of the output does not reach the set amplitude(4.5v) unlike the positive part.
How the circuit works: the Vcc switches the Vdc on and off. In on position, Vcc allows two cycles(two oscillations of Vdc) to pass.
Anything im missing here?
38,936
An NPN transistor can only have positive voltage on the collector. You are applying plus and minus voltages. You must add a +4.5V offset to the AC voltage so it goes between 0V and 9V positive voltage.
kenny-one
Joined Apr 21, 2010
37
I still cant get anything ut if this. It seems like is quite difficult to do this offset thing, since nobody seems to be coming with a precise solution.
How do i go about doing it?
absf
Joined Dec 29, 2010
1,968
To offset the sine wave by 4.5V on the simulator is easy. Just change the VDC "sine (0 4.5 40k 1n 1n)" to "sine (4.5 4.5 40k 1n 1n)".
In real circuit, you need a DC of 4.5V super-imposed with sine wave of 4.5V amplitude on the VDC.
Allen
kenny-one
Joined Apr 21, 2010
37
yes, coz i have designed a wein bridge oscillator that gives around 4.5 Vp. so what circuit would enable me to shift it to 0-9v?
