Help to use transistor mosfet
hakraf
Joined Jun 29, 2018
11
I'm new with you here and this my first thread, and i'm beginner in electronics, i'm doing some works and tests, i used a transistor mosfet BSS138L as a switch to power an relay, after reading the datasheet the Gate−Source Threshold Voltage is Min 0.85v and the Max is 1.5v and that's what i want, but when i try to power it, it need 3v to achieve the voltage i want (VDS)
this is the circuit schematic
VCC : 12v
I want to power this transistor with 2.5v as max voltage that i can provide because it is a PMW signal.
Thanks in advance.
AlbertHall
Joined Jun 4, 2014
12,628
Which MOSFET are you actually using?
The BSS138L, from the datasheet, has a resistance of 10Ω maximum at 200mA with a gate source voltage of 2.75V.
18,112
... the datasheet the Gate−Source Threshold Voltage is Min 0.85v and the Max is 1.5v and that's what i want...
You may be misunderstanding what that spec means: It means the max threshold voltage is 1.5V. That doesn't mean the MOSFET will be full conducting at 1.5V, it means it is just starting to conduct. It will not be fully on (below 2Ω) until the gate reaches about 4V or so.
hakraf
Joined Jun 29, 2018
11
I am understood now, thanks for explanation, so my question now is there some transistor or something i can do to achieve full conducting at 2.5v as maximum voltage at the gate?
18,112
You might use a BJT to drive the gate of the MOSFET. The BJT turns fully on at 0.7V. The MOSFET is still useful to avoid the BJT’s base current requirement if you are switching a “big” load. If the load is small, you might just use BJT alone.
cmartinez
Joined Jan 17, 2007
8,782
VCC : 12v
Thanks in advance.
You don't need a 1k resistor (R17) at the mosfet's gate, since mosfets are voltage-driven (unlike transistors, which are current-driven). The mosfet's gate acts like a capacitor, which stops drawing current after it's fully charged. In fact, R17 is actually hindering the way the mosfet works and it would be much better if you were to simply remove it. Sometimes small resistors are used (in the order of 10 to 50 ohms) at a mosfet's gate when the device is switched at high frequencies (about above 100 kHz or so), but they're there to prevent "ringing", which is a phenomenon that results in the gate's false triggering. At low frequencies, a mosfet does not need a gate resistor whatsoever.
