The following shows the diagram for a sensing and filtering input of a break-wire alarm. The CMOS logic input is held low by the break-wire ( 60ft long) and goes high once the wire is broken. The triggering voltage for the logic high is around 6V when Vcc is 10v. R2 needs to be very high to minimise the current consumption, as the circuit is battery operated. I'd like any suggestion and opinion to help to improve this circuit to maximise immunity against RFI, EMI and other induced noises. Would the addition of an inductor improve the function? Regards
