Hello, My first post here,
I have a 1982 Phillips Berlina Coupe SE with the original AM FM Cassette radio and the Motorola male end pulled off when I was disconnecting from the radio and broke off the tiny inner wire inside the cable.
Inside has an electronic part with "75 J" written on it. I was successful to simply solder the break back together with continuity.
But I soldered the Motorola Male connector housing to the 90 degree metal cable cover so it couldn't pull apart again and I believe I over heated the "75 J" electronic in the process.
I believe the "75 J" electronic is a filter to control noise from the power antenna when it is raised and lowered.
Can anyone help me to identify the "75 J" part and source a replacement? I can replace the entire cable but is a huge job because it is routed under the glued down carpet.
Thx in advance, John
https://scontent.fyxd1-1.fna.fbcdn....=94b329ac3d0c97f71f7dbdda1b3df493&oe=5C2B7764
