HELP to identify a power supply
captoro
Joined Jun 21, 2009
207
That! Just jumper them, why do you have resistors in there? Remove the resistors and place jumpers across those terminals.
Ron
Works if I just use a jumper. On the second post, Sagor said to add a 100ohm resistor.
thanks for your help
Ken
28,196
It may be that the shutdown is caused by an incorrectly adjusted overcurrent shutdown circuit, or possibly overvoltage trip circuit. I did see a bunch of adjustment positions in an earlier photo. None of the loads you mentioned is a heavy load, so the AK comment does not apply here. Is it the whole supply shurs down, or just one output? If it is the whole supply then that is a different issue.
captoro
Joined Jun 21, 2009
207
JUst the output I am using shuts down. GUess it is a protection of some sort.
ken
