Help to connect PC to Android 11 Tablet RT2
frank55
Joined Dec 6, 2013
314
Hi folks Can you guys help me to connect my Tablet Oukitel RT 2 android 11 to my Desktop PC Lenovo Thinkcentre M91, Win 10 ,i use USB cable it detects MTP USB device but not connect ,Check for drivers but it says the ones i'm using are updated for all USB ports. can connect my Samsung galaxy Android phone though.
Is there an easy way to get it connected so i can transfer files safely without paying to much money?thanks
geekoftheweek
Joined Oct 6, 2013
1,429
Have you checked your tablet settings? Sometimes there are multiple protocols the tablets can use for USB and they don't always have MTP enabled by default. It seems like it should be based on it detects a MTP USB device, but that may have more to do with how the tablet identifies itself to the computer than how it's configured.
frank55
Joined Dec 6, 2013
314
Thanks mate; but i don't see anything in the setting related to USB type -c , It has input USB Type -c ,i can connect the cable and it charges from the USB Port from PC , i also downloaded from here Drivers for Oukitel RT2 https://gsmusbdriver.com/oukitel-rt2#driver2, but i update but still says present drivers are good for Device.
geekoftheweek
Joined Oct 6, 2013
1,429
I finely found USB setting on the tablet See attach pic, i tried them all no avail;
That was what I was thinking. I forgot you had to enable developer settings to get to those settings which makes me believe you should not have had to do that in the first place. It should connect properly without having to enable developer settings.
Are you connected to your PC in the picture? The bottom radio buttons should be active if you are connected.
