Help PC Report
biferi
Joined Apr 14, 2017
541
I wanted to ask about the Report I get from the program HWINFO 64 about my Memory?
Under where it says Memory Modules it says Size and give the Memory Size for the stick I have.
Right next to it it says Clock and it says 1600 MHz.
Now under where it says Motherboard it says ChipSet under that it says BIOS under that it says Memory under that it says Size under that it says Clock 1329.9 MHz.
So what is this Clock telling me?
Is this telling me my MotherBoard is Runing my Memory at 1329.9 MHz?
If so why does the other Clock under Memory Modules say 16000 MHz?
I Uploaded a ScreenShot of the Report.
sghioto
Joined Dec 31, 2017
8,763
The RAM can run at 1600mhz if the CPU can support it.
I don't think it can run faster then the CPU speed.
bertus
Joined Apr 5, 2008
23,031
The info chip of the memory reports the maximum speed is 1600 MHz.
The motherboard uses 1333 MHz for the memory, wich is close to the calculates 1329.9 MHz.
Bertus
biferi
Joined Apr 14, 2017
541
So if I understand you my Memory can Run up to 1600 MHz but my Motherboard is Running my Memory at 1333 MHz?
