help on simple power supply using circuit wizard
Johnson Andres Gangob
Joined Jan 24, 2019
good day
i'm new in using circuit wizard and i'm having a hard time setting up a simple power supply, especially on the transformer windings. I can't get a 3 amps 24v during simulation.
given:
transformer:
primary: 240v 1amps
secondary:24v 3 amps
ericgibbs
Joined Jan 29, 2010
21,542
hi JAG,
Welcome to AAC.
I do not use Circuit Wizard, but where are you measuring the Vdc output from the bridge rectifier, also where is the smoothing capacitor.?
Mark it on your diagram.
E
Joined Jan 24, 2019
thank you, here is the updated diagram. i measure the vdc and i got 23v, however, i only get 100mA using an altimeter. in addition, when i replace the voltmeter on the circuit wizard with an filter capacitor 1000micro farad 100v and put an fuse, all components explode
jayanthd
Joined Jul 4, 2015
945
There is no load resistor and ground connection in bridge rectifier circuit.
Joined Jan 24, 2019
where should i put it and what should be the value.
btw can you recomendme a free electronic offline simulator other than circuit wizard, it seems i cant change the transformers output current
jayanthd
Joined Jul 4, 2015
945
What load current you want ? See attached video.
Extract the .rar file using WinRaR 5.x and view the .wmv video file in Windows Media Player or VLC Player.
AC mains voltage = 240V rms 50 Hz
Trf ratio is 10:1 step-down
Secondary voltage is 24V AC rms
DC output voltage across load = (24V * 1.4142) - 1.4 [2 X 0.7, (0.7 = 1 diode drop] = 33.9408 - 1.4 = 32.5408V DC.
You cannot change transformer current without changing the load resistor.
Vpri/Vsec = Npri/Nsec = Isec/Ipri
Set RL in my circuit to get the required secondary and primary currents.
I don;t know about any free offline electronic circuit simulator. I have licensed version of Proteus. I don't use Circuit Wizard much.
jayanthd
Joined Jul 4, 2015
945
Primary currents depends upon the secondary current and secondary current depends upon load RL here.
Vpri/Vsec = Isec/Ipri = Npri/Nec
240/24 = 10 is not equal to 3A/1A = 3 but 240/24 = 10 = 10:1 ratio that is Npri/Nsec = 10/1; 10 turns of primary = 1 turns of secondary.
If you want Isec = 3A rms then
Ipri = Isec / (Vpri/Vsec) = 3A/(240V/24V) = 3A/10V = 0.3A = 300mA.
Edit:
LaTeX
\({Ipri = Isec / (Vpri/Vsec) = 3A/(240V/24V) = 3A/10 = 0.3A = 300mA}\)
bertus
Joined Apr 5, 2008
22,994
You made a mistake in your explanation:
There can not be V at the given point.
Ipri = Isec / (Vpri/Vsec) = 3A/(240V/24V) = 3A/10 = 0.3A = 300mA.
Bertus
jayanthd
Joined Jul 4, 2015
945
DC output voltage across load = ((24V * 1.4142) - 1.4) [1.4 = 2 X 0.7, (0.7 = 1 diode drop] = (33.9408V - 1.4) = 32.5408V DC.
In image RL (Load Resistance) = 10k and IL (Load Current) = 3.22mA
IL = Vdc/RL = 32.5408/10k = 3.25408mA (approx same as in simulation (image)).
