Help on equipment perfomance
AlbertHall
Joined Jun 4, 2014
12,652
Generally here (UK) equipment has a rating plate which says what voltage and current the device needs but this will be a typical or maximum value.
When you say minimum do you mean like a TV with a low power standby mode?
rutendo
Joined Sep 24, 2017
10
The minimum for appliances to operate lets say tv rated at xWatts but can still work at (x/2)Watts,so i am asking is there is sort of a percentage tolerance i can look up to when i want to see the least it needs to power on
