Help needed with designing a safety circuit to ignite a pyrotechnic device
ih96
Joined Dec 24, 2015
8
Hi, I have been given a project to design a circuit which will ignite a pyrotechnic flare after a certain sequence of events has been detected. The events which must be detected are:
-A specific signal transitions from a short circuit to an open circuit.
-A short pulse signal from a separate detector is received.
-A 5V logic signal transitions from logic 0 to logic 1.
Additionally, the sequence in which these events occur is unknown.
I have a massive interest in electronics but only a limited knowledge which I have gained from my university course (Physics), so I am struggling to know where to begin with this project. I need advice on which components the circuit should contain in order to detect these events and if wiring them in a particular way may work better than others. I'm kind of viewing this as a learning experience, any suggestions or explanations offered will be thoroughly appreciated. I will do my best to try to understand!
wayneh
Joined Sep 9, 2010
17,505
Can these events happen at any time, in any order, or can there be some sort of time window? They do not need to all be "true" simultaneously?
A microprocessor may be in your future. There's a learning curve.
joeyd999
Joined Jun 6, 2011
5,439
CPU? How about 3 flip-flops and an AND gate?
I don't like the problem definition. Basically, any 2 of 3 events "arm" the device. The 3rd event is the trigger. Once armed, the device is 'unsafe' from here to eternity. Imagine the pulse and transition arm the device. Attempts to disassemble after that trigger it.
I would have added a rule that says, "all three events must occur within a defined period of time".
ih96
Joined Dec 24, 2015
8
My understanding is that they will happen at different times, but all of them need to have happened for the device to be ignited.
ih96
Joined Dec 24, 2015
8
That's a good point. Perhaps that is something which I should incorporate into the circuit? The task does specify that safety is essential to the design, but I don't want to overcomplicate things as I am already stretched by this.
joeyd999
Joined Jun 6, 2011
5,439
If I were defining the problem, this is the way I would do it:
1. Change short-to-open to open-to-short. This could be an arming key;
2. The logic '1' level could represent a 'dead-man's-switch'. Must be '1' at time of triggering.
3. The pulse would be the actual trigger.
#3 will do nothing unless both the key is in the armed position, and the logic '1' is present.
ih96
Joined Dec 24, 2015
8
Whilst I do agree with you and think that's a more practical solution, isn't that working on the assumption that the other 2 events occur before the pulse? Which wouldn't be a viable design for this task, as it's specified that the events can occur in any order.
Bernard
Joined Aug 7, 2008
5,784
I would put a time limit of say 10 sec. from first event. Let each event trigger a 10 sec. one shot, AND the one shots for firing signal.
joeyd999
Joined Jun 6, 2011
5,439
The 'key' would have to be in the armed position AND the 'dead-man switch' must be actively held before the 'trigger' would function.
Turning the key to the disarmed position OR releasing the dead-man switch disables the trigger.
The 'trigger' is a pulse (i.e. trigger occurs on an edge). If the first two conditions are not TRUE at the time of the edge, nothing happens.
hp1729
Joined Nov 23, 2015
2,304
Maybe a few words on how to convert your cell phone or remote control car, airplane or helicopter to a "pyrotechnic device"? I wouldn't touch this post for any reason. :)
There is a handy CIA manual for this. (Dang, I guess that book must be 20 years old by now. Quite obsolete.)
joeyd999
Joined Jun 6, 2011
5,439
Electronic launchers are available retail for model rocketry. Plans for this kind of stuff are available all over the internet. If he had nefarious purposes, he would not need to come here.
And, safety would not be his primary concern.
hp1729
Joined Nov 23, 2015
2,304
:) Okay, you help him. :)
ih96
Joined Dec 24, 2015
8
Well, that makes all the difference then. Why do you think we'd let you play in our sandbox?
Just kidding!
Welcome. We have few of the gender challenged here. :D
(Again, Just Kidding!!!!)
Hah, it's fine. I know it's not relevant, I just read the word 'him' too many times and thought I'd better mention it. Anyway, thanks for your advice and I think it's a good idea to design a circuit in which the trigger only ignites the device if the other key and switch are actively held. How could I do this whilst still having the specific signal transition from short to open? It's just that I don't want to redfine the problem as they may frown upon me not keeping to the brief.
#12
Joined Nov 30, 2010
18,224
First, "safe" and "random" are mutually exclusive.
Second, a voltage supply through a resistor can be shorted to ground. When you release the short, low becomes high. Single pole, double throw switch chooses between high and ground.
wayneh
Joined Sep 9, 2010
17,505
Of course it's also possible they want to see how you perform under pressure, whether you are willing to sacrifice good practice and safety just to satisfy management. Just sayin'.
Bernard
Joined Aug 7, 2008
5,784
Here is a sketch of what a firing circuit might look like.
A Manual NC pushbutton SW.
B Pos. pulse triggers 30 sec. OS.
C Lo to hi logic signal triggers a 30 sec OS
All 3 states are monitored by red & green LED's. If all green we should hear the bang.
Select transistor for current required by squib.
