Help needed with component identity
MaxHeadRoom
Joined Jul 18, 2013
30,661
no Idea how it detached I know where it fits the tangs are still in place I tried the mig it powers up but does not arc, opened side panel and found it In the bottom.
Usually cause by poor connection offering resistance = heat.
If you can clean all connections thoroughly first in order to make good connection, with plenty of solder flow, it should be OK for a while.
There is obviously a fair current running through that part of the circuit as it is.
Max.
killivolt
Joined Jan 10, 2010
836
Max.
I found this one looks like the N38-20 might mean 20 watt. This one is 20 ohm 25 watt 10%
https://www.mouser.com/ProductDetail/Ohmite/D25K20RE?qs=sGAEpiMZZMtlubZbdhIBIO0G6VCMyNyNl2MPXkpRxkM=
kv
killivolt
Joined Jan 10, 2010
836
LesJones
Joined Jan 8, 2017
4,511
I have found a link to a copy of the schematic which is readable. This is the link. I have not yet found the resistor on the schematic. NOTE The red download text that you have to click on does not appear straight away. (It takes several tens of seconds.)
Gary, Can you tell us where this resistor was located ? ( On the circuit board (If so what is the component designation ?), or some other place in the welder. ) Does the main contactor pull in when the trigger is pressed ?
Les.
Tonyr1084
Joined Sep 24, 2015
9,744
Powers up and feeds wire but no arc? Sounds like the broken link in the chain. Replace the component and I bet it will work. Won't bet much, I can't afford to lose too much, but I'm willing to bet a buck. (not really)
27,522
If a resistor that size is not supported and there is some lead length then it can vibrate and the copper conductors break. I had to repair a quite expensive multi-speed shop fan with that exact problem. The resistor lead simply broke. So at this point , having seen the photos, I would say it is 2 ohms. But still it needs to be replaced and for that a location is required and that will take a person who understands what they are looking for to find. And if the TS has no clue it will be a big challenge to find the spot where the green thing is not.
Ylli
Joined Nov 13, 2015
1,092
Can we get some pictures of the insides of the welder, particularly where the part fell off? From the low resolution schematic available (without a parts list), it looks like it might be R1. But if it is, R1 missing should not make the unit inoperative. As was asked above, does it sound like the main contactor pulls in when you pull the trigger?
Gary swift
Joined Mar 27, 2019
21
Placed the resister where it came from it does sound like it pulls in sounds like it did before it stopped working
Gary swift
Joined Mar 27, 2019
21
Just checked main contractor does not pull in
