MaxHeadRoom
- Joined Jul 18, 2013
- 30,661
At that WATTAGE?I see 200 meg, plus or minus 5% post #13, 3rd picture to the right.
kv
I see the individual turns on it.
@Gary swift Why no meter check??
Max.
kv
Faint striations might suggest fairly thick resistance wire under the glaze.I see 200 meg, plus or minus 5% post #13, 3rd picture to the right.
kv
It’s a murex 135 mug welder if this helpsAlso, if you can find a schematic of the welder would be good. I've looked everywhere and can't seem to find anything like it.
kv
Can you measure the resistance with a DMM?It’s a murex 135 mug welder if this helps
After five requests now , it may not be forthcoming!.Can you measure the resistance with a DMM?
Possibly not, but hope springs eternal... and in the spirit of the season, I hold out hope.After five requests now , it may not be forthcoming!.
Max.
I still see plus over minus after 200m then 5%.Best I can do with iPhoto. Still can't tell if that's 200M ±5% or 2Ω0M. For that fact I can't tell for sure WHAT it is. If the glare could be completely eliminated I still don't think we're going to get the clearest picture of it. If you have a multi-meter please check the resistance if you can.View attachment 173556
kv
I suspect this is a bleeder resistor, so, it is a safety feature that should be in place even if the welder "works".Why didn't any one ask the biggest question about this? Does the welder work??? It hasn't been mentioned yet. If it works, without this being in place, all of this is for naught.
This is good but where is the original link, include it please we need the complete schematic. I'm sure others would be interested in finding the source of the part. Next is why it burnt off or rusted, if it's a power resistor it makes sense why it came off, most likely poor solder joint after hrs of welding.
kv
Dmm 20.3Can you measure the resistance with a DMM?
It powers up wire feed works but no arcWhy didn't any one ask the biggest question about this? Does the welder work??? It hasn't been mentioned yet. If it works, without this being in place, all of this is for naught.
Yay. It's a 20Ω Resistor.Dmm 20.3
Il give it a goYay. It's a 20Ω Resistor.
At a guess, it's 50W, based on appearance.
It's still good, if you can manage to reattach it to where it fell off, it should work.
no Idea how it detached I know where it fits the tangs are still in place I tried the mig it powers up but does not arc, opened side panel and found it In the bottom.This is good but where is the original link, include it please we need the complete schematic. I'm sure others would be interested in finding the source of the part. Next is why it burnt off or rusted, if it's a power resistor it makes sense why it came off, most likely poor solder joint after hrs of welding.
kv
