Help measuring millivolts with this multimeter
MrSalts
Joined Apr 2, 2020
2,767
Turn the knob to 200m near the 9-O'clock position.
that scale will read from 1 to 200mV with the highest resolution. If you are measuring 200mV to 2 volt angle, the change to the 2V range jsut next to the 200m range.
I am assuming you mean milliVolts DC. Your meter cannot measure low voltage AC.
SamR
Joined Mar 19, 2019
5,542
Also understand that the Scale is 0-200mv and that a reading on that scale of 0.001 is actually 1uV. Would have helped to be able to see the resolution of the display, ie how many digits it is. Also read the specifications of the meter in your manual for it.
