I was wondering about those labels. The stack is labeled wrong for getting the intuitive concept across.Be careful. I think the stack begins at Stack Base. So the first value of 3 should be at location Stack Base. The first PUSH instruction would put the value 1 at Stack Base + 1.
Also, the Zero Flag in the non-existent status register would be set on the last two instructions, it's sometimes faster to check the zero flag than to compare to zero after an operation.Ok thanks!
I was thinking in RPN, the best calculator OS around, from HP. Give a 35s a try!Yeah the stack + 3 is the top of the stack, so stack base initially contains value 3. Also, ADD/MULS apparently does not delete the 2nd top element...it just takes result and overwrites top element (according to Professor for this problem only).
