hi all,
i had already designed a microphone amplifier from two op amp stages with finally an output stage (common collector)
the problem is the impedance of the loudspeaker is 8 ohm,so when i placed it as R load of the common collector it works fine but with dc shift in the output so i put a capacitor in series with it to remove dc but when i put that capacitor the output gone and be unpredictable
this is the schematic of the circuit from multisim
