Help me find these elements on my board.(PC PSU)
jpanhalt
Joined Jan 18, 2008
11,087
So...
watching http://www.electronicrepairguide.com/atx-power-supply-repair-guide.html and
http://www.electronicrepairguide.com/images/checkallcomponents.jpg
i see one resistance
2 ICs - are they always optocoupler?
one small resistance
one small electrolytic capacitor
One resistance
and at the end one Diode
How to locate them on my board
LPX6 200W
View attachment 153081 View attachment 153082 View attachment 153083 View attachment 153084 View attachment 153085
thanks in advance!
If you see them, then what's the problem locating them?
Without any other information, if I were to guess, it looks like a switch mode power supply for something.
UnnamedUser159
Joined May 3, 2016
501
i am seeing elements with arrows on the guide in WWW. i am searching for them in My board.
it`s already written what is this device.
jpanhalt
Joined Jan 18, 2008
11,087
The repair links you gave are for different supplies than the one you have. Are you trying to repair the one you have? What were the symptoms that make you think it is defective?
IC's are not always optocouplers.
UnnamedUser159
Joined May 3, 2016
501
Are you trying to repair the one you have? yes
it`s deffective because it has not even 5v stb. Power fet on first heat sink was dead. It was
P10NK60ZFP and i have replaced today with P10NK70ZFP but there is no effect.
the fuse is healthy. bridge rectifier is ok.
I am really gratefull for the help
