Help! Learning led driver
Joao12300
Joined Jul 3, 2021
6
Hello! I dont work on eletronics professional, but my goal is to learn the working principle of eletronics.
Im starting to study an led driver i took measures values and made the schematic diagram on easyeda now i want to understand what every resistor or any component do on the pcb.
im sorry for my english.
Photos:20220410_135724.jpgEsquema EasyEDA.png
ci139
Joined Jul 11, 2016
1,982
The YT2201's datasheet - nor the schematic diagram of - nor the pinout of -- will show up when googled in english
You seem to got the model of the chip ? anything ... block diagram
PS! - either your schematic (for the circuit diagram) or the pin-out of the mystery controller is incorrect
Joao12300
Joined Jul 3, 2021
6
sorry i forgot to explain i didnt used the right ic in the easyeda i didnt know how to change and make a custom ic the datasheet its correct
ci139
Joined Jul 11, 2016
1,982
? do you got the d/s for the YT2212 (←which might be not the correct or full product type-name)
? do you know the spec.-s for the LED supply/driver it.. (the power converter module) ..comes from // -- such as input voltage , output current or voltage . . . ?anything
Joao12300
Joined Jul 3, 2021
6
i got the d/s for the yt2201. about the specs the led driver has in the input 230vac, 78vdc on output and its feedding 96 2835 leds in 24 row of 4 led in series / parallel
Joao12300
Joined Jul 3, 2021
6
i guess (not yet digged into your PCB) that what you got is similar to the inverting buck/boost converter - as in
https://www.led-professional.com/te...argeting-100-w-incandescent-bulb-replacements
yup its similiar the diference that my pcb uses a ic that doesnt need auxiliary components to be powered or anything else thats why i picked this pcb so its an "easy" to understand then i will move to harder pcb to learn more.
my problem it is the need of someone that can explain how it works or like the diode close to the inductor what it he doing there.
thank you
ci139
Joined Jul 11, 2016
1,982
there is a theoretical chance that the circuit you got . . . is regulated
if the input is known (can be measured) and the target output voltage is known and the inductance is known - then it is possible to calculate the di/dt ← which can be measured either internally inside the IC or from the voltage drop on the R3||R4 (889mΩ) - so - if you can scope the waveforns - you may be able to get from these how the converter works
Joao12300
Joined Jul 3, 2021
6
i never calculated di/dt i will need to learn about that, about the scope i get this one from the inductor
ci139
Joined Jul 11, 2016
1,982
interesting "party" with all sorts of relevant figures
(( though it's interesting that the (hi "resolution" figure) 76.0657 does not match some less definitive 12.93 ))
basically i attempted to compile a fast simulation - while i realized that due the requirement for a separate startup control and the precision timings for the regular control the poor performance thingy - such as Falstad - goes too slow (← anyway the "regular control" "waveform generator") - the only option other than differential is to sample output when the mosfet is closed and the inductor has been settled . . .
. . . your waveforms don't hint that particular option ??
? was there a regular (96x .06·3.1≈18W) load on the output
there are some basic formulas at https://www.maximintegrated.com/en/design/technical-documents/tutorials/2/2031.html
basically for \(-\epsilon=L\frac{di}{dt}\) the \(V_{CHARGE-UP}=400-78V=322\) and the \(V_{CHARGE-DN}=78V\) which for a linear time integration (loosely put) defines the difference for \(I=\frac{dq}{dt}=\int{di}\) , also \(\frac{I_{MAX}}{dI_{IN}}=N·dt\) and \(\frac{I_{MAX}}{dI_{OUT}}=M·dt\) . . . as \(di~\epsilon\ or\ V\) the
\[{{}\\ \displaystyle{\frac{N}{M}=\frac{V_{OUT}}{V_{IN}}≈\frac1{\frac1{DUTY\ RATIO}-1}}}\]
so if we fix the \(I_{MAX}\) and the I/O voltages differ more then reaching \(I_{MAX}\) is faster and vice versa - so we have switching times and can measure average input voltage . . . is one way for a robust control
Jon Chandler
Joined Jun 12, 2008
1,586
Please, to get a complete explanation and understanding of LED driver chips, check out Big Clive on YouTube. He has disassembled many LED bulbs and explained their operation in great detsil.
