its almost the same with the 1st question, but juz want to ask that should i compress the last 3 resistor 1st?
It is true that the 8 ohm resistor in series with the parallel combination of the 3 ohm and the 6 ohm resistor is 10 ohm, however I was referring to the individual 10 resistor on the left side of your circuit.is the back one, but how about the 1st 10 ohm?
