Help in surge immunity compliance
dineshkakubal
Joined Aug 18, 2020
5
I have a tension controller board, for which power supply is given using "1757242" connector.
The supply voltage is 24V, current is around 10A.
I want to add a TVS diode for the input to comply with EN-61000-6-2:2005. (Presently it is failing the test)
I am planning to add a TVS diode at the input to gnd. Is that the correct method?
And what is the diode i have to select?
Thanks,
Dinesh KS
Delta Prime
Joined Nov 15, 2019
1,311
hello there
:) Electromagnetic compatibility (EMC) - Part 6-2: Generic standards - Immunity for industrial environments.
No test is given so there's nothing to fail.
You either pass the acceptance test or you do not. I do too much aerospace DO 19 acceptance testing.
TVS diode added to your circuit no problemo. I need to see a schematic. Pleeease. :)
Hymie
Joined Mar 30, 2018
1,347
You don’t specify whether you are talking about the AC or DC power ports – either way the TVS diodes (or other voltage clamping components) should have a breakdown voltage well above normal operating voltages.
Besides placing the TVS diodes to ground, you may need one fitted between supply lines.
In a 230Vac mains powered product, a typical varistor between supply lines and earth might have a continuous rating of 300Vac, with a breakdown voltage exceeding 600V – nonetheless such components will provide surge immunity protection.
TVS diodes have a much faster response than varistors.
dineshkakubal
Joined Aug 18, 2020
5
hello there
Here is the schematic part:
Only reverse polarity protection is present.
Thanks,
Dinesh kS
dineshkakubal
Joined Aug 18, 2020
5
It is DC power.
Presently i am planning to use "CPDQC3V3A-HF" diode. Will this work for the purpose?
Please guide me.
Thanks,
Dinesh KS
Hymie
Joined Mar 30, 2018
1,347
The proposed diode has a breakdown voltage of less than 4V, I suggest a CPDQR24V-HF diode which has a breakdown voltage of 28V.
