Help in snubber circuit design for a H-bridge
chrislee84
Joined Dec 8, 2007
14
The image below is the H-bridge that i have design and make out.
This h-bridge is a 24V and use to drive a DC brush motor which is 24V, 150W. After i test it, the driver can work but when i switch the direction, the lower part N-mosfet will burn. Because of this, I want to include snubber circuit to protect my mosfet and the motor but i don't know how to design it. Is the RC snubber is suitable or the RCD snubber is suitable And how to calculate the value of R,C and/D?
Can anyone help ? What actually parameter that i have to find to design the snubber circuit?
beenthere
Joined Apr 20, 2004
15,819
A diode across the FET's in reverse bias is usually enough for protection. Your image is thumbnail size, so I can't make out any details.
Are your FET's mounted on heat sinks? Are you certain they switch cleanly between conduction and turn-off? The current is not that high, so I would suspect something like operating in the linear region might be the problem.
chrislee84
Joined Dec 8, 2007
14
sorry, the image i upload previously got something wrong, the below one is the right one:
At the center of the upper and the lower mosfet is connect with the motor which i do not show.
Dear beenthere, what u mean by this?
The mosfet is mouted with heatsink already. Does i include the reverse bias diode, i no need to design the snubber circuit for the protection purposes?
The N-mosfet i use is the IRFP260N and the P-mosfet i use is the FQA47P06 and below is the link of the datasheet of both mosfet:
N-mosfet(IRFP260N): http://www.irf.com/product-info/datasheets/data/irfp260n.pdf
P-mosfet(FQA47P06): http://www.tranzistoare.ro/datasheets3/fairchild/FQA47P06.pdf
As shown in the datasheet, both of the mosfet have the internal reverse diode, does this enough for my application and i do not have include the snubber circuit to protect the mosfet and the motor?
beenthere
Joined Apr 20, 2004
15,819
There is an internal diode intrinsic to the structure of a power FET, but it is not intended for the kind of conduction necessary to protect the device from a high induced reverse voltage. It takes an external diode to do that.
chrislee84
Joined Dec 8, 2007
14
Hi beenthere,
Actually how i want to chose the correct diode for the reverse diode?
What i want to consider is it the current that the diode can sustain?
The battery i use is 24V/9Ah, so the current may be shoot very high.
So, how i wanna chose the right one for the diode.
As i know, is it the schottkey diode is better?
Hope to hear your reply soon.
nanovate
Joined May 7, 2007
666
The body diode can usually handle the current but I think it is the reverse recovery time that is the problem-- an external Schottky is usually better.
