Help in simplifying an Arduino sketch
TrmickCO
Joined Oct 9, 2016
72
I've just started reading/learning about Arduino and the programming involved. I'm really fascinated by sensors and their practicality, so I picked up the book "Make: Getting Started with Arduino" for next to nothing, used. I'm doing the irrigation project in chapter 8. I need to make sure some sensitive plants get watered on a regular schedule. I'm not having any hardware issues (I enjoy that!), just programming issues. The thing is, I don't want to use the DHT11 temp/humidity sensor at all, and simply want to turn a single water valve on at a certain time possibly daily (project uses the DS1307 RTC).
I've attached a link to the final sketch in the book. Is it possible to just delete the parts out related to the DHT11 sensor? Being an absolute newbie in programming I couldn't be sure if I was removing something still necessary to basic operation. In the end all I'm doing is using a RTC to activate a relay which turns a single pump on for a very short time.
https://resources.oreilly.com/examples/0636920029267/blob/master/ch08/example_8_4.ino
shteii01
Joined Feb 19, 2010
4,647
I am posting this to make sure that OP successfully tricks you into rewriting the program for 'em.
Code:
Example 8-4. The irrigation system sketch
Sketch to accompany the automatic garden irrigation system in
"Getting Started With Arduino, Third Edition". See that book for
the schematic.
http://shop.oreilly.com/product/0636920029267.do
09/04/2014 - Written by Michael Shiloh
12/09/2014 - 1) When displaying on and off times,
              must convert back to hours and minutes
              2) Humidity threshold was too low
              3) Forgot to set digital pins as output
              4) new function printSettings() since the same
              thing was being done in two different places
This example code is in the public domain.
#include <Wire.h>   // Wire library, used by RTC library
#include "RTClib.h" // RTC library
#include "DHT.h"    // DHT temperature/humidity sensor library
// Analog pin usage
const int RTC_5V_PIN = A3;
const int RTC_GND_PIN = A2;
// Digital pin usage
const int DHT_PIN  = 2;     // temperature/humidity sensor
const int WATER_VALVE_0_PIN = 8;
const int WATER_VALVE_1_PIN = 7;
const int WATER_VALVE_2_PIN = 4;
const int NUMBEROFVALVES = 3; // How many valves we have
const int NUMBEROFTIMES = 2;  // How many times we have
// Array to store ON and OFF times for each valve
// Store this time as the number of minutes since midnight
// to make calculations easier
int onOffTimes [NUMBEROFVALVES][NUMBEROFTIMES];
int valvePinNumbers[NUMBEROFVALVES];
// Which column is ON time and which is OFF time
const int ONTIME = 0;
const int OFFTIME = 1;
#define DHTTYPE DHT11
DHT dht(DHT_PIN, DHTTYPE); // Create a DHT object
RTC_DS1307 rtc;    // Create an RTC object
// Global variables set and used in different functions
DateTime dateTimeNow; // to store results from the RTC
// to store humidity result from the DHT11 sensor
float humidityNow;
void setup(){
  // Power and ground to RTC
  pinMode(RTC_5V_PIN, OUTPUT);
  pinMode(RTC_GND_PIN, OUTPUT);
  digitalWrite(RTC_5V_PIN, HIGH);
  digitalWrite(RTC_GND_PIN, LOW);
  // Initialize the wire library
  #ifdef AVR
    Wire.begin();
  #else
    // Shield I2C pins connect to alt I2C bus on Arduino Due
    Wire1.begin();
  #endif
  rtc.begin();        // Initialize the RTC object
  dht.begin();        // Initialize the DHT object
  Serial.begin(9600); // Initialize the Serial object
  // Set the water valve pin numbers into the array
  valvePinNumbers[0] = WATER_VALVE_0_PIN;
  valvePinNumbers[1] = WATER_VALVE_1_PIN;
  valvePinNumbers[2] = WATER_VALVE_2_PIN;
  // and set those pins all to outputs
  for (int valve = 0; valve < NUMBEROFVALVES; valve++) {
    pinMode(valvePinNumbers[valve], OUTPUT);
void loop() {
  // Remind user briefly of possible commands
  Serial.print("Type 'P' to print settings or ");
  Serial.println("'S2N13:45' to set valve 2 ON time to 13:34");
  // Get (and print) the current date, time,
  // temperature, and humidity
  getTimeTempHumidity();
  // Check for request from the user
  checkUserInteraction();
  // Check to see whether it's time to turn any valve ON or OFF
  checkTimeControlValves();
  // No need to do this too frequently
  delay(5000);
* Get, and print, the current date, time,
* humidity, and temperature
void getTimeTempHumidity() {
  // Get and print the current time
  dateTimeNow = rtc.now();
  if (! rtc.isrunning()) {
    Serial.println("RTC is NOT running!");
    // use this to set the RTC to the date and time
    // this sketch was compiled
    // use this ONCE and then comment it out
    // rtc.adjust(DateTime(__DATE__, __TIME__));
    return; // if the RTC is not running don't continue
  Serial.print(dateTimeNow.hour(), DEC);
  Serial.print(':');
  Serial.print(dateTimeNow.minute(), DEC);
  Serial.print(':');
  Serial.print(dateTimeNow.second(), DEC);
  // Get and print the current temperature and humidity
  humidityNow = dht.readHumidity();
  // Read temperature as Celsius
  float t = dht.readTemperature();
  // Read temperature as Fahrenheit
  float f = dht.readTemperature(true);
  // Check if any reads failed and exit early (to try again).
  if (isnan(humidityNow) || isnan(t) || isnan(f)) {
    Serial.println("Failed to read from DHT sensor!");
    return; // if the DHT is not running don't continue;
  Serial.print(" Humidity ");
  Serial.print(humidityNow);
  Serial.print("% ");
  Serial.print("Temp ");
  Serial.print(t);
  Serial.print("C ");
  Serial.print(f);
  Serial.print("F");
  Serial.println();
} // end of getTimeTempHumidity()
* Check for user interaction, which will be in the form of
* something typed on the serial monitor
* If there is anything, make sure it's proper, and perform the
* requested action
void checkUserInteraction() {
  // Check for user interaction
  while (Serial.available() > 0) {
    // The first character tells us what to expect
    // for the rest of the line
    char temp = Serial.read();
    // If the first character is 'P' then
    // print the current settings
    // and break out of the while() loop
    if ( temp == 'P') {
      printSettings();
      Serial.flush();
      break;
    } // end of printing current settings
    // If first character is 'S' then the rest will be a setting
    else if ( temp == 'S') {
      expectValveSetting();
    // Otherwise, it's an error.
    // Remind the user what the choices are
    else
      printMenu();
      Serial.flush();
      break;
  } // end of processing user interaction
* Read a string of the form "2N13:45" and separate it
* into the valve number, the letter indicating ON or OFF,
* and the time
void expectValveSetting() {
  // The first integer should be the valve number
  int valveNumber = Serial.parseInt();
  // the next character should be either N or F
  char onOff = Serial.read();
  // next should come the hour
  int desiredHour = Serial.parseInt();
  // the next character should be ':'
  if (Serial.read() != ':') {
    Serial.println("no : found"); // Sanity check
    Serial.flush();
    return;
  // next should come the minutes
  int desiredMinutes = Serial.parseInt();
  // finally expect a newline which is the end of
  // the sentence:
  if (Serial.read() != '\n') { // Sanity check
    Serial.println(
      "Make sure to end your request with a Newline");
    Serial.flush();
    return;
  // Convert the desired hour and minute time
  // to the number of minutes since midnight
  int desiredMinutesSinceMidnight
    = (desiredHour*60 + desiredMinutes);
  // Now that we have all the information set it into the array
  // in the correct row and column
  if ( onOff == 'N') { // it's an ON time
    onOffTimes[valveNumber][ONTIME]
    = desiredMinutesSinceMidnight;
  else if ( onOff == 'F') { // it's an OFF time
    onOffTimes[valveNumber][OFFTIME]
  else { // user didn't use N or F
    Serial.print("You must use upper case N or F ");
    Serial.println("to indicate ON time or OFF time");
    Serial.flush();
    return;
  // now print the entire array so user can see what they set
  printSettings();
} // end of expectValveSetting()
void checkTimeControlValves() {
  // First figure out how many minutes have passed
  // since midnight, since we store ON and OFF time
  // as the number of minutes since midnight.  The
  // biggest number will be at 2359 which is
  // 23 * 60 + 59 = 1159 which is less than the
  // maximum that can be stored in an integer so an
  // int is big enough
  int nowMinutesSinceMidnight =
    (dateTimeNow.hour() * 60) + dateTimeNow.minute();
  // Now check the array for each valve
  Serial.print("Valve ");
    Serial.print(valve);
    Serial.print(" is now ");
    if ( ( nowMinutesSinceMidnight >=
           onOffTimes[valve][ONTIME]) &&
         ( nowMinutesSinceMidnight <
           onOffTimes[valve][OFFTIME]) ) {
      // Before we turn a valve on make sure it's not raining
      if ( humidityNow > 70 ) {
        // It's raining; turn the valve OFF
        Serial.print(" OFF ");
        digitalWrite(valvePinNumbers[valve], LOW);
      else {
        // No rain and it's time to turn the valve ON
        Serial.print(" ON ");
        digitalWrite(valvePinNumbers[valve], HIGH);
      } // end of checking for rain
    } // end of checking for time to turn valve ON
    else {
    Serial.println();
  } // end of looping over each valve
  Serial.println();
void printMenu() {
  Serial.println(
    "Please enter P to print the current settings");
  Serial.println(
    "Please enter S2N13:45 to set valve 2 ON time to 13:34");
void printSettings(){
  // Print the current on and off settings, converting the
  // number of minutes since midnight back to the time
  // in hours and minutes
  Serial.println();
    Serial.print(" will turn ON at ");
    // integer division by 60 gives the hours
    // since integer division drops any remainder
    Serial.print((onOffTimes[valve][ONTIME])/60);
    Serial.print(":");
    // the minutes are the remainder after dividing by 60.
    // get the remainder with the modulo (%) operator
    Serial.print((onOffTimes[valve][ONTIME])%(60));
    Serial.print(" and will turn OFF at ");
    Serial.print((onOffTimes[valve][OFFTIME])/60); // hours
    Serial.print(":");
    Serial.print((onOffTimes[valve][OFFTIME])%(60)); // minutes
    Serial.println();
TrmickCO
Joined Oct 9, 2016
72
Code:
the schematic.
// Analog pin usage
float humidityNow;
void setup(){
  #ifdef AVR
    Wire.begin();
  #else
    Wire1.begin();
  #endif
void loop() {
  delay(5000);
  Serial.print(':');
  Serial.print(':');
  Serial.print("% ");
  Serial.print(t);
  Serial.print("C ");
  Serial.print(f);
  Serial.print("F");
  Serial.println();
* requested action
    if ( temp == 'P') {
      printSettings();
      Serial.flush();
      break;
    else
      printMenu();
      Serial.flush();
      break;
* and the time
    Serial.flush();
    return;
  // the sentence:
    Serial.println(
    Serial.flush();
    return;
    Serial.flush();
    return;
  printSettings();
      else {
    else {
    Serial.println();
  Serial.println();
void printMenu() {
  Serial.println(
  Serial.println(
  Serial.println();
    Serial.print(":");
    Serial.print(":");
    Serial.println();
I'm not sure I understand what you mean exactly. I'm not asking anybody to write anything for me. I was looking for some input as to whether it could be as simple as removing the sections dealing with the DHT11 and if I can still be left with a functioning program for the purposes I described. Not looking for anything more.
It is always better for anyone, newcomer or otherwise, to fully understand the code before customizing it for your own needs. In a way, you may be asking for trouble. I assume that you have the hardware according to the schematic - right?
That being said, after browsing the code, it looks like you can remove the DHT parts and still have a functioning program.
Note that in the valve operation code void checkTimeControlValves(), you see these lines:
Code:
      else {
These will have to be modified as well. The original code looks like the intention is that when the DHT humidity value > 70 (RH% I presume), the programming assumes that it is raining (not a good idea in my opinion, but that is a different matter) and skips valve operation.
TrmickCO
Joined Oct 9, 2016
72
Code:
      else {
Code:
      else {
Yes, everything is according to the schematic and all the hardware checks out fine. Thanks for the input about the DHT. I'm going to attempt to modify it (and hopefully gain more of an understanding in the process)when I get home tomorrow. Honestly, as helpful as this project is in learning some concepts, the DHT part is almost useless for my application. Also, when I tested it by itself(DHT11) it proved super inaccurate when I compared it to other sources I have. A quick search and I found many other people expressed the same thing.
