Help Identifying Part
34,809
What is wrong with the switch?
It is a simple SPDT (Single-Pole Double-Throw) switch.
Get a small flat metal file and gently clean the contacts.
Do not use sandpaper.
Reloadron
Joined Jan 15, 2015
7,889
Looks to me like an everyday cam switch with a single pole and one normally open and one normally closed contact with a common. When the cam rotates the switch opens and closes based on cam position. Sort of crude but looke like they should work fine, I see two of them.
I see Mr Chips has replied. Yes, I would just clean the contacts as described.
Ron
JK!
Joined Aug 9, 2018
Thanks Chips,
I believe the contacts are not connecting as the should on the right switch. I think the little part in the middle should be to the right in this position. Do you think so as well?
JK!
Joined Aug 9, 2018
Yes, your right! I never noticed that until right now.
So, how do I find the replacement for that ...
Thanks for all the help!
