Help identifying LED part please
kevinlong
Joined Nov 20, 2018
I am trying to fix an LED reading lamp (this one: https://www.wayfair.com/lighting/pdx/brayden-studio-barton-52-task-floor-lamp-brsd3504.html )
I've removed the LED element and was hoping to try to order a replacement somehow. It was soldered in with 2 wires. It appears to be a tiny circular PCB that is attached to a circular piece of metal which may or may not be part of the "part" I am looking for.
Any help appreciated ! See attached pic if you think you might be able to help. Thanks
dl324
Joined Mar 30, 2015
18,439
Welcome to AAC!
My guess is that it's a white power LED on a heatsink.
Would be surprised if the LED is bad. The supporting electronics is usually the weak part, in particular caps that get fried from high temperature.
kevinlong
Joined Nov 20, 2018
Welcome to AAC!
Thanks @dl324 . I should have mentioned the symptom was that it was intermittent, on/off and varying levels of brightness. Tapping the lamp anywhere would make it switch on/off or less bright/more bright.
dl324
Joined Mar 30, 2015
18,439
Bond wires in LEDs can do that. I have an LED flashlight that blinks. When I turn it off and let the offendling LED cool down, it stops blinking. In my case, I know it's the LED because there's no electronics.
I have a couple CREE 60W equivalent LED bulbs that blink intermittently. Still haven't gotten around to taking one apart to see I can isolate the cause.
If you can measure the LED current and voltage, it'll give you a better idea of the power rating. If it's driven with a current source, that'll complicate things because you won't be able to measure current.
