Help identifying burnt component
Strebor71
Joined Jul 24, 2020
6
Hi all, I have a portable bug zapper that stopped working, I replaced the battery and bulb still didn’t work. Opened it up to investigate further and discovered what appears to be a burnt transistor. It’s burnt to the point that all but the last 2 numbers on it are readable which are 9C. I have taken photos of the board, hopefully someone can help with suggesting a replacement part so I can get this thing working again.
The part missing is where you see the burnt spot just the the left of the center of the board.
dl324
Joined Mar 30, 2015
18,426
You only have two possible polarities. If you reverse engineer the circuitry around the transistor, you could probably figure out the important parameters.
What makes you think it will start working if you replace the clearly defective component? If you don't remove what caused the fault, a replacement transistor would burn up and, next time, it might cause a fire.
Strebor71
Joined Jul 24, 2020
6
I am fairly certain that it was due to the wrong charger being used. it was supposed to be a 6.5v and a 12v was plugged into it for several hours.
dl324
Joined Mar 30, 2015
18,426
Then trace the circuitry around the transistor and just use a circle/box to represent the transistor; but label the terminals.
dl324
Joined Mar 30, 2015
18,426
I am not sure what you are asking me to do.
Trace the circuitry around the transistor and make a schematic. There's most likely a resistor connected to the base. Draw it, give it a component designator, and record its value.
Keep tracing back through additional components until we get enough circuitry to determine transistor polarity and important parameters.
jpanhalt
Joined Jan 18, 2008
11,087
I doubt you will find the exact replacement. Even if you knew the part number, that might be obsolete.
I did a parametric search on DigiKey for high-voltage transistors in similar cases. The list is fairly short:1595627018709.png
Here's the search: https://www.digikey.com/products/en/discrete-semiconductor-products/transistors-bipolar-bjt-single/276?k=transistor&k=&pkeyword=transistor&sv=0&sf=1&FV=16|413090,16|413297,16|413514,69|411897,74|380569,74|380584,1291|405480,1291|405596,1291|412988,1291|412994,1291|412997,1291|413296,1291|413505,1291|413513,mu1.5kV|2103,mu1000V|2103,mu1100V|2103,mu1200V|2103,mu2200V|2103,mu400V|2103,mu420V|2103,mu425V|2103,mu440V|2103,mu450V|2103,mu460V|2103,mu465V|2103,mu480V|2103,mu500V|2103,mu525V|2103,mu550V|2103,mu560V|2103,mu600V|2103,mu650V|2103,mu700V|2103,mu750V|2103,mu800V|2103,mu825V|2103,mu900V|2103,-8|276,1989|0,1989|7&quantity=&ColumnSort=0&page=1&stock=1&pageSize=25
All but one are under $1. Model aircraft ignition systems use a similar design to make a voltage of about 250 V to 300 V which then feeds a spark coil. I would try any of the 400 V rated units (they are cheaper) with the highest current. The TS13005 looks similar to an ST1300x version that is obsolete, but the link to TS is broken. Just be sure collector is the middle pin (most are).
Strebor71
Joined Jul 24, 2020
6
Sutton's Law:* Get a new one.
*https://en.wikipedia.org/wiki/Willie_Sutton
https://en.wikipedia.org/wiki/Sutton's_law
Edit: Added reference to "Sutton's Law" based on an allegorical tail involving Willie Sutton. Didn't realize Wikipedia actually had that heading.
someone forgot about the meaning of "HOBBY". Why would I bother coming on here and getting help from all these folks, if I didn't want to fix it. I realize i could get a new one for $80 but why when i could spend less than $5 and learn something doing it myself.
jpanhalt
Joined Jan 18, 2008
11,087
I am all for fixing stuff. I do it all the time, and not uncommonly, my result is better than the original. It boils down to the extent of the damage and to what extent you will go to fix it.
If you can repair that for less than $5.00, I will reimburse you, assuming you are in the US. Save all receipts, even for things that didn't work out, and get pictures.
