Hello guys! I am deisgning a sine wave generator that MUST provide accurate sine wave at desired frequency, in my case 5.5 Mhz.
this is the basic schematic, I decided to stop on Colpitis sine wave generator and ADD a crystal to stabilize the frequency further.
The voltage to power the board can be either 5 volts or 12 volts stabilized (or eventualy 12 volt battery that can range a little but that is not problem.)
What I need is:
To know where exactly is the output for the sine wave.
To be able to calculate all the resistors and eliminate all unnecessary resistors; Help with calculating the AMPLITUDE of the sine wave signal in Volts. I think its best to add some trimmer (potentiometer) because I need to be able to vary the amplitude of the sine wave from 0.5 to at least 5-6 volts or even more. Where should I add the pot?
Finally, where should I add the crystal? Should it be the same frequency as the one I want to have?
As far as the 2 capacitors connected to the inductor, I have already calculated them using this calculator to match 5.5 Mhz, so I dont think I will need help with that for now.
Heres is the schematic and link for Colpitis sine wave calculator I used.
http://www.ekswai.com/en_cap3.htm
http://i45.tinypic.com/6sykud.jpg
Thank you very much in advance!
What I need is:
