help for 400 hz generator
Abdennasser Chicouche
Joined Nov 19, 2017
hello every one
i have project about electrical generator with 400 hz frequency
i want ask about method or the circuit to get this frequency from MPSG magnet permanent synchronous generator 50 hz
help me please
thanks .
Reloadron
Joined Jan 15, 2015
7,960
One common solution as Alec pointed out is a MG (Motor Generator). Other than 50 Hz and 400 Hz you make no mention of your required voltage and current. Motor generators normally come with a KVA rating. Years ago I used KATO Motor Generator solutions for my 400 Hz power. You need to define your power needs? Anyway depending on needs a MG solution or an Inverter solid state solution.
Ron
