Help for 3 phase inverter project to change 24V DC to 120V AC
circuitbird
Joined Oct 21, 2015
2
Hi all
I'm trying to design a 3 phase inverter to change 24V DC to 120V AC and wondering how should i start
this is my first project so it will be great if someone can help me out
Thanks
GS3
Joined Sep 21, 2007
408
You want to *design* a converter from 24 Vdc to 120 V ac, 3 phase? I would not recommend such a project to a beginner.
DickCappels
Joined Aug 21, 2008
10,187
You should start by detailing your requirements; output power, regulation, harmonic distortion, etc. After that, try making a single phase converter and get that working before bothering with a full three phase converter.
GS3
Joined Sep 21, 2007
408
You need to define your requirements but, in any case, this is definitely not a project for beginners.
A 3 phase power supply is going to be something handling serious power capable of running motors and other big loads.
Your household inverter has a FET H bridge but for inductive loads you are going to have to seriously redesign it for inductive loads.
Then you will need to have three separate inverters with a single control unit which switches them 120º apart.
Plus protections, etc.
