help finding DC-DC converter
panic mode
Joined Oct 10, 2011
4,978
hello everyone,
i am looking for 500-600W DC/DC converter with CSA or UL approval.
input voltage 48V, output is 24V.
there is tons of solutions but not with mentioned approvals.
Vicor modules are approved but they don't have conventional terminations (lugs, terminal blocks, molded wires etc.) - solder connections or multi-contact terminals are not fit for this case.
Any suggestions?
panic mode
Joined Oct 10, 2011
4,978
well i could do that of course. even so, issue here also very long lead time of 16 weeks. i don't have 16 days, more like 1.6 days :)
ebp
Joined Feb 8, 2018
2,332
TDK-Lambda is the only other manufacturer of "bricks" that comes to mind. I don't know if they produce anything that would suit your requirements.
Beware of deciding you can live with Vicor's terminals & going to a broker to beat long delivery times. Vicor has had quite a problem with counterfeits.
27,513
Check the DigiKey catalog, they offer a lot of modular power supplies and you can usually get next day delivery. They are not cheap but they are good.
