and I can't seem to find you. Would you like those capacitors in Thailand? Denmark? Arizona?i cant seem to find this capacitor
north carolina usaand I can't seem to find you. Would you like those capacitors in Thailand? Denmark? Arizona?
i did try digikey and had looked at mouser but cant find the same one,found close but at a $1 apiece and over what i am looking should be $35 for 100There are some on this page, but there seems to be some mistakes on the page, too. Do you know about Digikey, Jameco, Allied, and other major suppliers?
http://www.mouser.com/Passive-Compo...apacitors/_/N-9x371?P=1z0wpzoZ1yo19mxZ1yx4avr
not quite the right i can find the right uf the right voltage but not materialI see. You actually did find the right part, you just want it cheaper by the hundred.
Sorry. Outside my area of expertise.
Next helper, please.
I handed you that answer in post #4.i can find the right uf the right voltage but not material
Check here. This may help you.i cant seem to find this capacitor
1.5kV 0.01uF Polypropylene Film/Foil Capacitors
thanks for the helpI handed you that answer in post #4.
Here it is boiled down to polypropylene only:
http://www.mouser.com/Passive-Compo...s/_/N-9x371?P=1z0wpzoZ1yo19mxZ1yx4avrZ1yznbzs
Ceramic is the cheap way to do this, under 19 cents in 100 quantities:
http://www.mouser.com/Passive-Compo...itors/_/N-5g8m?P=1z0wpzoZ1yo19mx&Ns=Pricing|0
