Hi all,
I’m working on a modular system with multiple carrier boards, each containing:
These carrier boards connect via a shared Ethernet backplane to a centralized ETH controller board. The controller board hosts:
Here’s a simplified block diagram of the setup (attached image):
System Hypotheses:
I’d appreciate guidance on these specific questions:
1. Magnetics — what’s actually required?
2. Can I connect all carrier boards in parallel to the same Ethernet traces (backplane)?
3. Is there a better way to achieve this?
Thanks in advance for any feedback! This is for a custom embedded project with tight space constraints and strict performance requirements.
- A CPU
- Ethernet PHY
- Magnetics
- An Ethernet switch
- Multiple PHYs + magnetics
- External RJ45s or optional ETH daughter boards for expansion
System Hypotheses:
- All carrier boards must access an external ETH daughter board via the controller.
- Carrier boards must be able to communicate with each other via Ethernet.
- The design should allow future ETH daughter board add-ons.
- Do both the carrier boards and the ETH controller board need magnetics?
- Or can PHY-to-switch connections over the backplane be done without transformers (e.g. using transformerless MDI coupling)?
- Will this create signal integrity problems or collisions?
- Or does each PHY need to connect to a dedicated switch port?
- Would you recommend a different topology (e.g., backplane with switch IC and SERDES lanes)?
- Any suggestions for improving modularity while maintaining Ethernet compliance?
