Whoops! Yes, you're correct. You're going to probably need a dual 555.. When I get back from the pub....but wouldn't this also trigger the pin on the lpt gate when I reset the system?
T = 1.1 × (R × C)First of all, thanks a lot for helping me out with this. You've put a lot of effort in it to help me and I really appreciate that!
About the 555: I would not mind working with other IC's but I know the 555 is an easy to get timer.
2 more questions:
1) how can I now determine the Time out of the first timer? I see I can change it by changing C6 and R4 but what is the formula to calculate the time? (I would like to replace R4 with a potentiometer to vary the time between about 1 and 5 sec).
Post what the output waveform is from the inductive sensor.2) how can I switch the Reset switch with an NPN sensor circuit like this oneto use the inductive sensor? What do I do with the 24V in contrary to the 5V the rest of the clogic circuit is running on?
The images that you posted has nothing to do with possible damage to a NPN transistor vs a PNP. Read again what it says In the application shown. They're more concerned with a sheath break causing a short to Gnd, thus causing a false actuation of a machine. It does not apply to anything I give you.By the way, is it possible to use a PNP sensor (as these are not damaged by short circuit)?
thanks
indeed, I see it now. I should have looked betterThe images that you posted has nothing to do with possible damage to a NPN transistor vs a PNP. Read again what it says In the application shown. They're more concerned with a sheath break causing a short to Gnd, thus causing a false actuation of a machine. It does not apply to anything I give you.
