Help 48V 12Ah Lead Axit Battery Charger Circuit
dknovo
Joined Sep 8, 2014
8
Hi everyone,
I'm designing a 48v lead battery charge circuit. However, I found a charger diagram designed for 24V lead axit battery, so can you help me modify the 24V battery charger circuit ( the components' value such as: R, C, Q ...) so that I apply the charger diagram for charging 48V lead axit battery.
Thanks you so much!
Here is my 24V charge diagram designed
Alec_t
Joined Sep 17, 2013
15,170
That circuit is a 12V battery charger. Have you posted the right one?
What is the manufacturer's recommended charge current for your battery?
MikeML
5,444
Converting that 12V charger to 48V would be just like starting from scratch. Most of the components will not stand operating on ~50V.
dknovo
Joined Sep 8, 2014
8
Thanks for your help!, I don't know how to design a 48V lead axit battery charger circuit. How I should do now ?, or Can you share me a 48V lead axit battery charger circuit.
22,116
I didn't know there was such a thing as a 48 V Lead Acid battery. But as others have said you will need entirely different components. Do they make datasheets for such batteries? I'd like to see one. That would be my starting point for a new design. Tell us how much you want to spend on developing this charger.
