HELP! 4 bit adder ic
royashley99
Joined Nov 20, 2021
47
When I connect all the pins to and I'm trying to add 2 binary numbers together it's just displaying the carryout pin as high when it should display 0100 on the output leds
royashley99
Joined Nov 20, 2021
47
I want to make a 4bit adder like the one in this video but when I connect it the output doesn't display what it is supposed to do
dl324
Joined Mar 30, 2015
18,453
Should I use transistors as switches and connect it to the main power
You could use BJTs, MOSFETs, buffers (e.g. CD4049, CD4050), etc. If you don't intend to use the adder outputs to drive other logic, you can do what you're doing, but you're never going to get 10's of mA with VCC=5V unless you use 74AC.
