Hello, could someone upload a CPL file?
panic mode
Joined Oct 10, 2011
5,307
it is not a project but production files (gerbers, drill). to export placement data you need access to actual PROJECT and then you can generate any reports yourself - including CPL, BOM, gerbers, etc. well... at least you should if you have correct software and know how to use it.
# Macchina M2
The Macchina M2 is a open-source, programmable interface with hardware support for most automotive protocols including CAN, SWCAN, LIN, J1850PWM, ISO9141, and KWP2000.
This repository contains open sourced files for to the M2 hardware. The **M2** folder contains files for the retail version of the M2. The **M2-B** contains the files for the beta board that was produced in limited numbers and sent to members of the Developer Program.
![Under-the-dash model](M2-B/M2-B_UTD.jpg)
The under-the-dash model, pictured above, plugs into your car's OBD2 port. The Macchina M2 is also available in an under-the-hood model.
The files in this repository are released under the [Creative Commons Attribution-ShareAlike 4.0 International (CC BY-SA) license](LICENSE).
To order visit https://www.macchina.cc/catalog
