Heatsinking techniques for SMD power LEDs
bh4017
Joined Feb 12, 2017
I am currently working on a personal project which uses a group of surface mount power LEDs.
The LEDs are available in two packages; one which is a simple surface mount device, and another which is the same device pre-mounted onto a regular "star" type heatsink base.
The heatsink base option provides a convenient thermal connection point for a heatsink, but unfortunately the group of LEDs together take up too much space in this package. So I need to make a custom solution (using a custom PCB) and provide adequate heatsinking for the LEDs myself.
I am wondering about techniques for generating optimum thermal transfer from the top-side of the PCB, where the LED will be mounted, and the bottom side.
I was thinking about covering the LED connection pads in lots of tiny through-hole-plated vias to try and take the heat down to the bottom side of the PCB, where I will make a heatsink connection.
I haven't tried this yet, but before I do I thought I'd ask the group here if anyone has better ideas.
Thanks!
dl324
Joined Mar 30, 2015
18,476
Welcome to AAC!
More typical to use the body of the device package for heat transfer.
EDIT: image upload problem fixed...
DickCappels
Joined Aug 21, 2008
10,661
The classic solution is to use a metal core printed circuit board.
In an early phase of design I made a prototype lamp using approx 0.02" thick copper clad FR-4, The interconnects for the LEDs are on the component side and all of the copper on the non-component side was left alone. The LEDs were soldered directly to the component side of the board. The non-component side of the circuit board was coated with a thin layer of Wakefield (or similar) heatsink compound and the board mounted on an aluminum heatsink. It worked pretty well.
