The transformer is wrong type, too high voltage. If you must go with such, then use at least switching type reg. to drop to closer to 12V so you don't need such huge drop done in LDO.Hello guys,
i need your help if possible. I created a dual voltage power supply using LM317 and a LM337 both in TO220. The problem is that when empty everything is ok but when I connect the load they heat up within two minutes also with heatsinks. I give a brief description of the circuit. The transformer generates me 17-0-17 Volt AC (150mA + 150mA I know it's small but it's just for testing) which rectified and stabilized become +22.8 0 -22.8 Volt DC. This is the input voltage to the voltage regulators. There are 6 of which three are negative and three positive where each one generates a different output voltage which is:
+/- 12 Volt
+/- 5 Volts
+/- 1.5 Volt
If you have space for bigger cooling fins then why not use it ?Actually I use a 12v ac and temp is lowered but need more heatsink or a fan. To do simply for testing I had tried the fan "undervolted" and the temp was stabilized at about 45°C , but supply stage must be redrawn.
How much area on the board, and how much vertical distance above the board do you have?Because i never found a good substitution to fit.
Just pick what you need, there is tons of different versions...Because i never found a good substitution to fit.
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Jake Hertz
