For safety reasons and to save time and money, I recommend NOT reinventing the wheel and building your own.Hey everyone got a question. I’m trying to build a small heating pad for my front porch but I’m having a hard time figuring out what I could use as a heating element. Any ideas?
Trying to make a rollout cover that will cover my patio so I don't have to shovel snow.What is the function of the pad, de-icing?
What Temp range?
There is Raychem Chemelex heat trace cable.Trying to make a rollout cover that will cover my patio so I don't have to shovel snow.
Probably 5’X10’There is Raychem Chemelex heat trace cable.
What do you consider "Small"?
May be a hard task to solve efficiently.![]()
How would it work if snow covered it though? Wouldn't it need light to reflect in order to be heated?For surface heating a radiant heat source is another option. It would avoid having anything electrical that would be subject to damage and become a hazard. Really, an an IR absorbing roll-out cover would not require any electrical connections and thus could be simpler and cost a lot less. And IR radiant heating is a mature technology with quite a few U.L Registered products available.
The Chemelex cable is also used to prevent eave troughs from freezing up.How would it work if snow covered it though? Wouldn't it need light to reflect in order to be heated?
