Here I am again. There must be another problem in my build. I come back here because I know its a piece of cake for many. I tried my best.
Define "fails".The voltage through the temperature sensor is too big and it fails. Adding another diode didnt seem to help.
What do you mean by "burn"?This is just a schematic I found on the internet and I was curious to try it out. By fail I mean burn, because the voltage is ~7.29V and the minimum allowed is 5.5V. The resistor values are taken from the site where the picture is from and it says that the temperature should not go over 125C. I guess you are supposed to change its sensitivity with the potentiometer, so no defined values of temperature.
Says what?This is what the simulator that I use says.
| Thread starter | Similar threads | Forum | Replies | Date |
Power transistor so much heat | Power Electronics | 8 | |
| V | Heat Detector Circuit | Sensor Design & Implementation | 6 | |
| V | Heat Detector Circuit | Sensor Design & Implementation | 5 | |
| Y | Automatic Heat Detector | Sensor Design & Implementation | 2 | |
| R | An automatic heat detector | Sensor Design & Implementation | 11 |
