Headphone amp power ?
andomando
Joined Jan 23, 2016
17
I have a LJM headphone amplifier kit,and i,d like to know what power supply to use with it
Info;input voltage AC15V-0-AC15.
Max output voltage +-14V
Max output cuuent 200ma...load 16-800 ohm.
Is there a power adaptor i can buy to use with this amp.
regards
Andrew
UK
Dodgydave
Joined Jun 22, 2012
11,395
You need to search for a 15-0-15v transformer @500mA or 1000mA, for the input voltage of your country, either 120V or 230V AC.
coolyyz321
Joined Mar 17, 2017
90
just look up "center tapped transformer" on google and you should find what you need. Afrotechmods has a great tutorial on transformers, take a look at the video if you want to know about these transformers, helped me my first time,
12,139
Finding a plug-in power supply with a center-tapped AC output will be difficult. Most likely you will need a transformer and a line cord. The transformer secondary rating should be 30 VCT (30 volts, center-tapped) but anything in the 28 to 33 V range will work. 500 mA (1/2 amp) or more is fine.
Please post a link to the kit.
andomando
Joined Jan 23, 2016
17
Thank you all for your answers to my question.I will look into finding item needed.
The only link i have is; EBAY,STORE=9cn8864
type in ;NEW LJM P7 SE PREAMP KIT Headphone Amplifier Kit.
If you type amp kit as above as i have written it, it should come up right away.
regards to all
