I got a cheap Chinese headlamp to see whether I can fix it and I need some help from experts. The headlamp is powered by two 18650 batteries. The problem is the light turns on when I insert only one battery and the switch does not work. Also, the LEDs that indicate charging glow red and green at the same time. Inserting the second battery does not change anything. Looking at the circuit board, there appears to be something melted bottom right...?
