HC-12 Radio module TX RX in Oshonsoft
ericgibbs
Joined Jan 29, 2010
21,569
hi C,
One reason why your results are hit/miss, you are sending "0" 0x0d, 0xoa ie: "0"<crlf>.
But you are only reading one byte at the receiver, leaving 0x0d,0x0a in the rx buffer.
I'm still working on the revised program.
E
ericgibbs
Joined Jan 29, 2010
21,569
hi C.
Try these two Basic programs [ currently set for SIM ], they work OK in Sim.
Make sure both TX and RX programs are either set for Sim or PIC.
The advantage of this method is that the number of Commands can be easily increased.
E
EDIT:
To Send to RXR
In Simulation the ? is seen as a LF
$0? or
$1?
The PIC RXR code will detect either the ? or LF as a end of msg terminator.
[No need to edit the code]
camerart
Joined Feb 25, 2013
3,853
hi C.
E
EDIT:
To Send to RXR
$0? or
$1?
Hi E,
Thanks, I'm just working through them both.
Glad you sent the EDIT:)
In PCB should it be:
main:
If button = 1 Then 'BUTTON NOT PRESSED
rled = 0
yled = 1
Hserout "$0", CrLf
Endif
WaitMs 500
If button = 0 Then 'BUTTON PRESSED
rled = 1
yled = 0
Hserout "$1", CrLf
Endif
WaitMs 500
Goto main
OR'------------------------------------------------------------------------------------
main:
rled = 0
yled = 1
Hserout $0, CrLf
Endif
WaitMs 500
rled = 1
yled = 0
Hserout $1, CrLf
Endif
WaitMs 500
Goto main
C.
ericgibbs
Joined Jan 29, 2010
21,569
hi C,
Unless I am losing it,
The two clips you posted are the same.??
Where is the RXR clip.?
E
main:
get_led:
rxi = 0
If RCSTA.OERR = 1 Then 'RCSTA BIT1-if over run error then flush RXD buffer
RCSTA.CREN = 0
RCSTA.CREN = 1
char = RCREG
PIR1.RCIF = 0
Endif
sync1: 'wait for a '$' start of string
If PIR1.RCIF = 0 Then Goto sync1
char = RCREG
If char <> 0x24 Then Goto sync1 '$'
str1(1) = char 'STR1 ARRAY
rxi = 2
get_msg: 'read and save
If PIR1.RCIF = 0 Then Goto get_msg
char = RCREG
str1(rxi) = char 'STR1 ARRAY
rxi = rxi + 1
If char = 0x0a Or char = 0x3f Then Goto decode 'tests for either LF or ?
Goto get_msg
decode:
If str1(2) = "0" Then
Hserout "Red Off,,,Yw On: ", CrLf
rled = 0
yled = 1
Endif
If str1(2) = "1" Then
Hserout "Red On,,,Yw Off: ", CrLf
rled = 1
yled = 0
Endif
Goto main
End
camerart
Joined Feb 25, 2013
3,853
hi C,
E
main:
get_led:
rxi = 0
RCSTA.CREN = 0
RCSTA.CREN = 1
char = RCREG
PIR1.RCIF = 0
Endif
char = RCREG
rxi = 2
char = RCREG
rxi = rxi + 1
Goto get_msg
decode:
rled = 0
yled = 1
Endif
rled = 1
yled = 0
Endif
Goto main
End
Hi E,
What is the last R in RXR?
When you say two clips the same, are you refering to #23, If so one has quotation marks, "$1" the other $1 or is it "$1?" or "$1LF" or no quotation marks at all?
I'll try again tomorrow.
C.
camerart
Joined Feb 25, 2013
3,853
Hi E,
I'm even lazier than that I use TX and RX.
Your RX works in SIM
In the TX I tried "1" and "$1"
TX is transmitting, here's a terminal view:
Between the two modules ther's no ON/OFF.
C
camerart
Joined Feb 25, 2013
3,853
hi C,
I don't understand what you are describing.??
Sending "1" without the '$' prefix is a waste of time.
E
Hi E,
IN SIM:
I've tried: Hserout "$1?", CrLf
This works.
ON PCB:
I'm using the MAIN LOOP from your #22 TX1
I've also tried Hserout "$1", CrLf
NO LED on RX.
Perhaps I've missed something, I'll recheck.
C.
ericgibbs
Joined Jan 29, 2010
21,569
hi C,
I assume the TX and RX are on the same channel.? and that channel is not being used by some other local persons TX/RX.?
Also the Baud rates are the same, I use 9600.?
I have my Power at P8, which is the highest specified power.
How far apart are the TX and RX modules.??
E
camerart
Joined Feb 25, 2013
3,853
hi C,
E
Hi E,
Same channel, tick
9600 , tick
correct range , tick
frequency--------------OOOps:eek:
Working now, thanks.
C.
ericgibbs
Joined Jan 29, 2010
21,569
hi C.
Pleased to hear it works OK.
If required you can now add more commands to the TX msg and decode them in the RX.
eg:
TX = $01<crlf> ' the state of two different p/b's
RX, check the str1(2) and str1(3) array locations and set LEDs' On Off, etc...
OK.?
E
rled = 0
yled = 1
Endif
rled = 1
yled = 0
Endif
If str1(3) = "0" Then
Hserout "Green Off,,,Blue On: ", CrLf
rled = 0
yled = 1
Endif
If str1(3) = "1" Then
Hserout "Green On,,,Blue Off: ", CrLf
rled = 1
yled = 0
Endif
E
camerart
Joined Feb 25, 2013
3,853
hi C.
eg:
OK.?
E
rled = 0
yled = 1
Endif
rled = 1
yled = 0
Endif
rled = 0
yled = 1
Endif
rled = 1
yled = 0
Endif
E
Hi E,
I'm now thinking about many uses, better stop for now.
I'll come back to this later, as I'm recalling the Tracker with comma positions too.
Cheers, C.
camerart
Joined Feb 25, 2013
3,853
hi C,
You cannot connect two TXD driver outputs together.
Connecting two RXD's reading inputs is OK, I often do that for monitoring.
Post a short Oshonsoft Basic program, say driving just two LED' s Red, Yellow I can check it for you.
E
Hi E,
I have some switching components in a 'basket' that will switch between two inputs into one, then I re-read your message.
As it is the RX that needs two inputs, I don't need to buy the switches, good!
Thanks, C
ericgibbs
Joined Jan 29, 2010
21,569
hi C,
Do you mean like this image.?
If Yes, it is OK.
I assume we are talking all at TTL Serial levels.?
E
Your description sounds incorrect.
ericgibbs
Joined Jan 29, 2010
21,569
hi C,
Have you considering using a Software serial input, using Oshonsoft Basic.?
I have used the Hardware and another Software Uart on a number of PIC projects
Clip from Manual;
DEFINE SEROUT_DELAYUS = 5000
SEROUT PORTC.6, 1200, "Hello world!", CrLf
DIM I AS BYTE loop:
SERIN PORTC.7, 9600, I
SEROUT PORTC.6, 9600, "Number: ", #I, CrLf
GOTO loop
E
