Having trouble Driving Darlington array from GPIO expander
deane1111
Joined Nov 3, 2022
9
I am new here so hope this is the right place.
I am trying to drive multiple max output of 500mA independently from a GPIO expander. I am connecting Darlington array NCV1413BDR2G directly to gpio expander PCA9675 as shown below.
For some reason, any U9 GPIO pin is held as a output low signal no matter how hard i try to make it high. I ended up getting it to work with 1k resistors pulled to 3V3 in-between U8 and U9. However, this circuit is used to drive a relay controlling motors. The motor is now defaulting on because it is active low.
I am not sure how to handle this now. I seem to need the pull up to toggle the output but that will run the motor. It doesnt seem easy to find PNP darlingtons at 7 channels like this. Is there a better way to approach this?
deane1111
Joined Nov 3, 2022
9
hi,
If you have the space, add HEF4049 inverters to the outputs of the expander
E
That would work however, not the most elegant solution. Perhaps with that said, I should select a different expander that can drive the darlingtons without the use of pullups. Maybe I can find one that will drop in and be easy....
deane1111
Joined Nov 3, 2022
9
You could also try switching to a MOSFET version of the load drivers.
This is what I really wanted to do! would solve all the problems..but I wasn't seeing very plentiful options of mosfet arrays. Maybe i am looking in the wrong place but I would like to be easily sustainable.
JohnInTX
Joined Jun 26, 2012
4,787
Take a look at the MCP23017:
https://www.microchip.com/en-us/product/MCP23017
16 bits of 25mA sink/source on each pin. Not a drop in replacement but could solve your source current problems in one place. There are probably others around but I've used these with success.
Good luck.
JohnInTX
Joined Jun 26, 2012
4,787
deane1111
Joined Nov 3, 2022
9
Thanks but i think that would be ok. I believe the PCA9675 max drive current is 25mA.
I replaced the darlington pack with TBD62003APG and as expected I no longer have a current driving problem but i do have a polarity issue still. Seems like the PCA9675 defaults as a input HIGH. I am not sure I understand this...Is this because of an internal pullup? Either way, I will either have to add an inverter or grab a expander that doesnt default this way.
Irving
Joined Jan 30, 2016
5,195
Correct.... as per datasheet... that's a crock, a sensible device would default to an input plus hi-Z tristate output, but no...
"This quasi-bidirectional I/O can be used as an input or output without the use of a control
signal for data directions. At power-on the I/Os are HIGH. In this mode only a current
source (IOH) to V DD is active "
I'd switch to the MCP23017 - proper tri-state outputs and no drive issues...
PaulJ2022
Joined Nov 10, 2022
Hi. Your theory of adding 1k resistors seems valid. But what if you include a diode between u8 and u9? Surely this will drive the circuit allowing control relays to operate?
