Hartley Oscillator using an Opamp
burhanuddin1999
Joined Dec 22, 2020
I was trying to derive a model for Opamp Hartley oscillator. I used a R at mouth of opam to increase the output impedance. So i tried including it in calculation. As the opamp is modeled as output voltage of Avi so using a R in series with it with help me to reconfigure the circuit changing the circuit voltage source into a current source using source transformation theorem. Here are my calculations. Can you tell me where i messed up.
LvW
Joined Jun 13, 2013
2,066
Sorry - but I must state that the opamp-based Hartley oscillator as shown in the linked document does not work. The circuit was derived from a transistor-based oscillator without considering the fact that the opamp is a voltage source (and not a current source). Hence, the inductor L2 acts as a pure load - and has no influence on the feedback path.
burhanuddin1999
Joined Dec 22, 2020
Hi, Yes i am aware of the problem that's why I attached an external resistance, Ro at ouput terminal. Then by using Norton Source transformation i transformed the voltage source Avi into a current source Avi/R
LvW
Joined Jun 13, 2013
2,066
And what is your problem now?
I think, it would be helpful to see the circuit diagram your eqivalent small-signal diagram is based on.
