Harmonics in power systems
Cerkit
Joined Jan 4, 2009
287
Hi.
I am desperate to understand how harmonics exist in power systems. I have read over and over about non linear loads and things such as rectifiers and power electronics which switch in and out the current abruptly.
Intuitively this doesn't help me understand physically what happens especially when most explanations start explaining it through Fourier transforms and decomposition of the frequency spectrum.
That is all well, my question is, is there a physical interpretation of how the source sine wave of 'F' frequency results in sine waves of multiples of this frequency? If I abruptly switch in and out and draw current at a particular interval of the voltage waveform periodically, as far as I am aware I am still utilizing this current at the same frequency as the source frequency where exactly are these new frequencies being generated from?
Or are you saying that it can not be viewed physically? It is a mathematical thing that I must just accept?
Thanks
22,116
The observable part of harmonics in power systems is the distortion in the waveform. It can be shown that non-ideal or distorted waveforms can be decomposed into into sums of sinewaves consisting of a fundamental frequency and an infinite number of harmonics. It can also be shown that each additional harmonic that is added reduces the error between the approximation and the actual waveform.
JWHassler
Joined Sep 25, 2013
308
Hi.
Thanks
The demonstration that got me to accept it was the addition of sines to make a square wave
