Hard to find NMOS
hhsting
Joined Apr 25, 2024
395
Does anyone here know of where I can find cheap thru hole vgs threshold of 1V, rds very very low so that it can be used as on or off switch to drive load, ids of 1.5A? Link please
WBahn
Joined Mar 31, 2012
33,202
Finding thru-hole parts is getting harder and harder every year, so the chance of finding a suitable such part goes down with time. There are lots of surface mount parts that have threshold voltages all around your 1 V target (but keep in mind that there can be a significant range of effective threshold voltages from part-to-part). Do searches on DigiKey or Mouser to explore what is available. Without knowing what, for you, constitutes "rds very very low", we can't help much. Similarly, without knowing what the max Vds is when off, we can't help too much.
hhsting
Joined Apr 25, 2024
395
How do I solder surface mount components in prefer board like this?
https://www.digikey.com/en/products...e=1&gbraid=0AAAAADrbLlhozHv6ho8PoIQF1UCwU1f1J
Papabravo
Joined Feb 24, 2006
22,111
Here is the TN0702 from Supertex. Vgs(th) = 0.8V (typ), and rds(on) = 1.9Ω (typ). Is that good enough?
Next time try the Digikey search tool, it works pretty well. Quantity 1 price is $1.52 from Digikey. For 100 pieces it is $1.14
dl324
Joined Mar 30, 2015
18,469
With a 3V signal, you don't need a threshold voltage of 1V. IRLZ44N would likely work. Threshold voltage is 1-2V. On resistance with Vgs=4V is 40mΩ.
If you go surface mount, AO3400 has a threshold voltage of 0.65-1.45V, on resistance is 52mΩ at Vgs=2.5V.
I use this adapter:
EDIT: add datasheets
SamR
Joined Mar 19, 2019
5,537
Hiw can you considered soldering legs? You know how small they are? Its hard to solder legs manually?
I would assume the SMD would be SOT23 or similar. Easy enough to tack on 24 or 22AWG wire to use for perf board through hole mounting. Wouldn't want to try it with 0403 resistors or caps but SOT23 isn't all that small. People do it all the time in a pinch when they have the SMD but not the through hole component. The only possible issue you may run into is not having a large surface contact solder pad to use as a heat sink. Sitting above the board on wire "stilts" does aid in cooling though. Just don't push the component very hard and give it plenty of current head room so it won't overheat. I posted a "typical" link for SMD to through hole adapters... Available from many sources and handy to keep on the shelf.
hhsting
Joined Apr 25, 2024
395
I use this adapter:
Wow thats very tiny. How did you solder that on the adapter? What kind of solder iron you used and solder?
dl324
Joined Mar 30, 2015
18,469
SC-89 is even smaller.
I use a Weller W-TCP with a 1/32" conical tip (PTP7) with wire solder (0.032" or 0.015") or solder paste. I use an iron even with the solder paste.
The adapters cost $0.10 each the last time I bought them from AliExpress. The leadframes are hard to find and cost about $0.10 each (qty 100) when you can find them. I have 4 types available in this barter thread.
hhsting
Joined Apr 25, 2024
395
What model iron you use?
