I had one of these batteries lying around and decided it would be fun to try charging it with my tiny DIY solar array.
The wall power adapter that came with the battery says it outputs 14V, 850mA.
My solar panels are giving about 14V, 650mA.
When I made the connection through the barrel jack, the charging indicators lit up and I thought, "wow, that was too easy...". Upon metering, though, I found it was only taking 50mA (probably just to power the LED indicators.)
I assume I'm triggering some kind of protection circuitry. With the help of a boost converter, I've managed to get the voltage within 0.01V of target, but the battery still says "no thanks." I'm sure I could take it apart and bypass the roadblock if I wanted to, but I don't need to charge the thing that bad. This was just an experiment.
My question is more just for general knowledge/curiosity: What obstacle have I likely come up against here? I suppose I could purchase a linear voltage regulator to get the volts closer to "perfect," but maybe the lower current would still be a problem anyway?
Thanks.
Thanks.
